Enigma acknowledge light
Tomhales
Post by Tomhales »
Checked engine parameters all normal. Indications normal acknowledge button resets low oil pressure but remains red any suggestions. Thanks Tom H
Re: Enigma acknowledge light
if your oil pressure is not within limits you set in your oil pressure setup menu acknowledging the alarm only shuts it up - it does not fix your oil pressure and it will remain in alarm condition.
Tomhales
Post by Tomhales »
Thanks. I will double check and let you know. Tom H
