iEFIS crashing when sending transponder code after firmware update
I just updated the iEFIS firmware to the most recent release and now every time I try to change transponder code it crashes the system. Any help would be greatly appreciated. Is there a store of past firmware to roll back to the last version? Thanks.
Re: iEFIS crashing when sending transponder code after firmware update
This issue is fixed, before software update having transponder and ADSB settings slaved did not cause an issue. After firmware update system was not happy with transponder and ADSB slave setting, unchecked slave setting and proper functionality returned.
