Manuals
jwaldrip
Manuals
Post by jwaldrip »
Where can you find the manuals for the G3 Challenger. The menus that I have downloaded for some things are not the same as the menu in my Challenger G3. Like the magnetic current sensor. I have it connected to RDAC #2 but I cannot find any way to do that in the menu. There are other
things that I'm finding out that the menu and choices are not the same. Very frustrating.
Re: Manuals
There is no menu option to use the current sensor on RDAC 2 as RDAC 1 if that is what you are intending to do.
If you want to use a current sensor connected to RDAC 2 then you need to customize your screen(s) to add a readout for it in the way you would like it.
If you want to use it on RDAC 2 instead of RDAC 1 for some reason you still need to customize - only you do not have to add anything, just tell the readout that exists to get its data from RDAC 2.
