Using iEfis Lite as GPS source for Trig TT22
Posted: Sun Apr 06, 2025 4:31 pm
by Still_Learning
Apologies for asking about what is probably a routine operation for most on this forum...
How do I use the iEfis lite as a GPS source for my Trig TT22? I have a head unit for the transponder so the Trig interface cable doesn't sound like the right solution.
Pin 5 on the TT22 seems to be GPS IN - but I have no idea how to connect this to the iEfis which has RS232 and CAN bus connectors.
I'd be very grateful if someone could either point me to a resource or jot down the steps I need to follow.
Thanks a mil
Andrew
P.S. I also see a TIS traffic out pin on the Trig - is that useful at all for displaying traffic on the iEfis?
Re: Using iEfis Lite as GPS source for Trig TT22
Posted: Tue Apr 08, 2025 7:24 pm
by krassovsky2000
Although I can't answer your question, I wanted to say that my understanding is that Discovery Lite GPS as a source is not precise enough for ADSB (there is a SIL incompatibility).
I had to additionally install MGL SP-12 as a source (and it's not available generally, I only found it in New Zealand) for the PAPR report to come back with no exceptions.
My suggestion is to get the Trig GPS source - seems like a high quality unit and you can integrate it per the instructions with it.
(I am in the US, so not sure if your country rules differ).
Posted: Sat Apr 12, 2025 4:23 am
by Still_Learning
Great thanks. From what I've been told it's sufficient: South Africa seems to require RTCA DO-260A standard and from my very basic research it seems that this standard is based on RTCA DO-229D - which the iEfis lite meets. But I'll do some investigation as we know where assumptions can land you...
I welcome any further thoughts from the forum... As well as any help in the wiring so I can at least get a test running.
@rainier I'm sure you could answer this in your sleep :)
Posted: Sat Jun 07, 2025 8:13 am
by Still_Learning
Managed to get feedback from Trig Support - they were very helpful. Pity not same level of assistance from MGL:
- Connect TX from RS-232 on the MGL Efis to GPS on the Trig TT22
- Connect GND between Efis and Trig
- On the Trig set the GPS source to be NMEA and the certification level to uncertified. Details on the setup in section 6.1 of the TT22 installation manual - https://www.trig-avionics.com/library/0 ... Manual.pdf
- on the MGL ensure the correct RS-232 port is configured for GPS, protocol set to NMEA and BAUD rate set to match Trig
Works like a dream
Hope this helps anyone else wanting to achieve the same
