2 virtual fuel tanks?
Posted: Thu Dec 14, 2023 12:14 pm
by Drummer Dan
Greetings everyone, and happy holidays! It's been a bit since i've been in the forum.
Brief inquiry—can I have two virtual fuel tanks on an Explorer Lite? If yes, any swift tips on how to configure?
Appreciate the help!
Dan
G-MUSO
Re: 2 virtual fuel tanks?
Posted: Thu Dec 14, 2023 5:01 pm
by gd5362
Hey Dan,
Yes you can have 2 virtual tanks. Go to the System Setup Menu and then select Fuel Related Setup and all your settings are there.
Also, thanks to a recent update, you can set low fuel warnings on these virtual tanks as well which you will find in the same menu selection.
Posted: Fri Dec 22, 2023 5:56 pm
by Drummer Dan
Thanks Glen, much appreciated.
I'm out at the airfield tomorrow and will have a go.
Happy holidays
Dan
gd5362 wrote: Thu Dec 14, 2023 5:01 pm
Hey Dan,
Posted: Sun Dec 24, 2023 2:53 pm
by Drummer Dan
Greetings everyone,
I'm still encountering a challenge in my setup. Currently, I can successfully display two real tanks and one virtual tank. However, when I choose two virtual tanks, only one appears alongside the 1 real tank.
My goal is to enable the selection of two virtual tanks only. Selectable and linked to my FT60 RedCube fuel flow sender.
Failing to figure this out, I will just go back to using 1 virtual tank as a totaliser and be done with it.
Many Thanks
Dan
Posted: Wed Dec 27, 2023 11:09 am
Using two virtual tanks (two flow senders) is quite possible but you need to create your own fuel display as that configuration is not part of the built in screens you can select. Base yours on the one with one virtual tank and use the screen designer to add the second - moving the bargraph and resizing to make space. Or do your own display from scratch - perhaps you would prefer to use two round gauges for the tanks ?
Posted: Thu Dec 28, 2023 7:11 pm
by Drummer Dan
HI Rainier
Thanks for the feedback.
I'm not up to speed on custom screen designing, but will have look in the new year.
Dan
