Re: Designer: Transponder / ADSB
Posted: Fri Feb 26, 2021 9:57 am
The signal strength is regulated basically between that of a class A and class B device. While this does make a difference to the range estimate (as you do not know the TX power of the source - you only know it is between X and Y), it still provides great value - the received signal strength drops by the square of the distance (so 4 times as much power for twice the distance). So given that, you could estimate a source say 5 miles or 10 miles away - in either case not much of an issue - but if 1 or 2 miles you may want to notify the pilot.
Sadly the mode-A and mode-C transmissions are identical in format so you cannot tell which is which - the mode-C is the more useful as it has altitude. And of course you can receive these things from a large number of aircraft and you don't have a clue if this is one or 100 aircraft. But you do have the signal strength - if it gets close it will be getting very strong - so you can warn. This is done by means of a "Ghost aircraft" that is shown with a unique call sign at the estimated distance to your right on the screen (rather than straight ahead). We don't know the direction so we put it at a known position relative to your own aircraft with a unique identifier. This way it is also compatible with other EFIS systems.
