Hi. I have 2 questions about the replay facility on the V16.
If you’re listening to a replay and a new transmission is received, does the replay terminate so you hear the new transmission, or does it just keep playing?
If you start a replay but only want to hear the opening 5 seconds, is there a way to terminate it.
Incoming RX cancels playback.
Should you wish to cancel a long playback simply press the PTT very briefly.
Usually playbacks are short so this is rarely done.
