Can we get another revision for Voyager gen2?
wdmac50
Post by wdmac50 »
I would really like to see at least one more revision of the Voyager gen2 firmware and simulator.
Biggest request would be to add a RDAC XF to the sensor simulation. Specifically to be able to use the aux1 and aux2 inputs for generic temperature sensing (LM335) or other functions such as a 0-5volt pressure sensor for cooling effectiveness evaluations. I see using diagnostics that these inputs make it to the EIFS, but there is no way access them for any purpose -- other than carb temperature for one of them.
Also, the GPS time set (auto update) is off by one hour for those of using negative offsets.
I think there are a few more things I could think of I put my mind to it -- but I have been replacing my engine over the last 2 1/ years and such things fall to the background when trying to fix engine failures. But I am now back at it so these are live issues again.
Thanks!
2x Voyager Gen2
RDAC XF
SP6
SP9
Mermaid Amphibian
USA
wdmac50
Re: Can we get another revision for Voyager gen2?
Post by wdmac50 »
Thought of another Item that needs fixing. The fuel pressure reading is not properly logged and is thus unavailable for later analysis. This is important to me because I had two engine failures in 2017 that put me on the ground and water. In both cases I think fuel was involved but I could not verify fuel pressure afterward.
2x Voyager Gen2
RDAC XF
SP6
SP9
Mermaid Amphibian
USA
