voltage monitoring on iEFIS lite
N43YX
Post by N43YX »
Is it possible to monitor two bus voltages on the iEFIS lite series?
N43YX
Re: voltage monitoring on iEFIS lite
Post by N43YX »
Bump. Rainier?
Yes.
You need the Extender.
Configure one of the analog inputs as you need.
Input voltage range goes up to about 15V - you can extend that with a series resistor (which forms a voltage divider with the input resistance) if you need to monitor a higher voltage.
You can simulate all of that in the simulator with simulated voltage. Set the scaling the way you want it (probably in 0.1V steps). Place readouts and or indicators attached to your chosen input as needed.
Rainier
