Xtreme EMS
Re: Xtreme EMS
Hi Mike,
Yeah, not much of a Sir, but happy to help.
mleimetter
Re: Xtreme EMS
Post by mleimetter »
Again thank you. Everything seems to be working fine now. I had a little trouble getting my EMS tach and stock tach to run concurrently, it was either one or the other. Finally figured out that the dip switches for RPM 1 were on, and when I turned them off it worked perfectly. I’m starting to like my EMS again lol. By the way, the answer to the coolant sensor problem was the ID10T builder. I realized that the RDAC has a coolant probe sensor slot, but for some reason the Extreme EMS does not recognize it. I had the EMS set on aux 1 for the coolant but it never synced in my head. Once I moved the coolant wire to Aux 1 on the RDAC it worked fine.
mleimetter
Re: Xtreme EMS
Hey JimJab I have another question please. I attempted to wire a gps source wire into pin 6 on the radio head per the manual. There was already a wire in that slot, and since the harness is tucked away, I’m not sure what it’s connected to. I tapped into that wire with the gps wire and got a “no radio” message. It’s a pre wired harness. Any help would be appreciated. What else could that wire be hooked up to.
