Iefis explorer modo espejo
Piterval
Post by Piterval »
Hola, he tenido el inconveniente que no me funciona el monitor colocado en mi plaza trasera de mi avión en tándem por la salida vga. Alguien sabe si tiene solución ese tema, tal vez alguna actualización de software?
Según el manual solo hay que conectar y ya funcionaría , ese no sería mi caso.
Gracias
Hello, I have had the inconvenience that the monitor placed in my back seat of my tandem plane does not work for the vga output. Does anyone know if that issue has a solution, maybe a software update?
According to the manual, you just have to connect and it would work, that would not be my case.
Thank you
Piterval
Re: Iefis explorer modo espejo
Post by Piterval »
Thank you
Which model EFIS are you using ?
Piterval
Post by Piterval »
Iefis explorer 8.5
Piterval
Post by Piterval »
Iefis 8.5 serial# ie 190200449
First update your EFIS firmware to this:
www.mglavionics.co.za/Beta/EXP3.BIN (That is the latest version but not officially released yet)
In Operations setup menu you will find an entry to select standard or low noise video timing.
Some monitors cannot handle the low refresh rates for the low noise option so please choose the standard video timing. It will be used the next time you reboot the system (go out of the menus first - it only gets saved if you exit the menus).
Piterval
Post by Piterval »
Hola, ya he podido resolver el problema. Muchas gracias. Saludos rainier.
